My propeller
Hi Everbody
Past the point of no return now.Have raised new post entitled "Would you cut off a propeller with an angle grinder?"The engineer at our boatyard wan'ts to hammer it off but is too busy to do it in the next fortnight!
I would avoid hammering it. Decent puller and heat. But, if you cut the hub in line with the shaft, using a thin multi material disc, it would not be neccessary to go right to the shaft, most of the way would take the stress off the hub and the puller would do the rest.
