Must have on boat ??
100PCS Solder Seal Wire Connector, Eventronic Heat Shrink Butt Terminals Electrical Insulated Marine Waterproof Automotive Copper Connectors with Case(35Red 30Blue 25White 10Yellow)
by Eventronic
4.6 out of 5 stars 49 customer reviews | 15 answered questions
Price: £14.99 Delivery at no additional cost for Prime Members
Note: This item is eligible for click and collect. Details
1 new from £14.99
Easy operation: Simply splice the wire together and slide the sleeve over it the same way you would with heat-shrink. Shrinking ratio: 3:1.
Dual-walled design: Provide strong hold, polyolefin tubing in outside and hot melt adhesive in inside. Allows visual inspection, prevents corrosion, and provided a waterproof seal.
Translucent heat shrink tubes ensure a high level tensile strength, and tear resistance and mechanical damage,provides insulation seal and with advanced waterproof function.
Material: High-class Tin, with lower melting point for easier application. High Quality: comply with all relevant European standards.
Application areas: Application in areas such as automotive, railway, watercraft, aerospace, electrical and electronics industries, etc.
Excellent idea, I hate soldering. More importantly, the bloke in the vid said he was a ROV operator and he called them ‘underwater robots’. I remember getting told off for calling them that:p
Just watched this Youtube video
So did I. Thanks for letting us know, the trick does look very neat indeed.
I just wonder if the central soldering bit isn't prone to oxidation over time, in a marine environment.
But maybe not, considering that it should be well protected by the plastic insulation...
On a side note, I very much sympathize with the Britalian family, of course. :encouragement:
But Rossella, please, replace that courtesy flag with a plain one: the defaced quartered shield is only meant for IT flagged boats. :rolleyes:
The only real problem with them is the low temperature solder - they're fine if you know they aren't going to have to cope with a higher temperature - definitely not certified for aviation use though, despite the aerospace comment. And why pull on the connections like that? A tension of that order is something it should never have to face and it tells you very little about the electrical connection - vibration, oxidation or temperature will get them eventually but nothing wrong with using them for non-critical systems. The only thing to watch out for is the heat source you use - if you can use a hot air gun on the heatshrink and save a fairly hot flame for the solder part you reduce the chance of melting the insulation under the heat shrink.
+1
and make sure when/if there's a short there low temp solder wont give up and make a nice arc or whatever there...
V.
PS. never seen them before, put them in my next basket!
just put "heat shrink solder sleeves" in on Ebay................ from about £3.00 delivered..
Ideal for use with a little gas powered heat gun.
Alibaba provides a lot of hits,most have min order of 10K.
I suspect they're just copies (whether that matters I'll let others decide).
The pukka items seem to be made by https://www.te.com.
Not sure I'd want to use them for critical applications long term but they feel like a worth addition to my spares box.
Like others, I think I'll buy some (<50!) and put them in a tray with some Wago connectors.
