Music in Different Zones of the Boat
We also brought a really funky blue tooth sound box at libs.
Had planned on using it for trips to the beach or the foredeck. Would prefer a more refined solution for the boat but budget will decide
I bought a Sonos system with plans to install in my boat, I wired it in roughly just to try out and found it worked well. I ended up connecting 2 Bowers and Wilkins speakers which I had spare to an old car amp, connected in turn to the Sonos with a couple of RCA cables. Sounded great but there was a couple of things I didn't like about it.
Firstly, the Sonos requires 240vac, I plan to fit an inverter soon but thought it'd be a shame to have the inverter running just to listen to music. Another problem was that I probably listen to the radio more than anything but how to source this into the Sonos?
Then I came across the Fusion MS-IP700i, has radio as well as numerous other possible sources, bluetooth, usb, ipod dock etc etc. Does everything I need and very well.
Worth noting that if you have a compatible garmin device, the latest software update gives you control for the fusion over the N2k network. Handy that you can use your flybridge plotter as a remote for your fusion.
ones you have the invertor installed, you can use it for many more 230V appliences, such as: 230V Fridges, Labtop and Mobile phone chargers, water cooker (!!power!!), etc...
For the radio, when you have a decent shore wifi connection, you can have internet radio on the Sonos,
or
you can install a domestic radio reveiver, and connected it on a RCA plugs input, available on some of the sonos speakers.
this Radio signal can then be routed to any speaker in your Sonos setup.
