Dazzajohm
N/A
I don’t seem to have much luck with boats... think I need to find another hobby...
Anyway, I’ve got twin TAMD41B’s with the MS4 gearbox. One side is fine, but a problem has developed on the stbd side where there is a delay when forwards is selected.
Was fine last season, but took boat for a run the other day, first time out the marina in a good few months and when I returned and was manoeuvring back in to my berth, there is a delay of 3 or 4 seconds when forwards is selected.
Had another look today as the boat has just been serviced over the past couple of days including gearbox oil change. Upon start up no problems engaging from cold but then after a run and everything is warm same as before with 3 or 4 second delay when forwards is engaged.
When I say a delay, when I watch the Shaft when forwards is engaged it does start to turn very slowly but it’s not noticeable for a few seconds.
I’ve had the cable disconnected from the lever on the gearbox and put it in gear by hand and the same thing happens so I know it’s not the cable.
Any ideas? Seems really strange that it seems to be without problem when cold and only evident when warm.
TIA
TIA
