Tim Good
Ok so following on from my last thread: http://www.ybw.com/forums/showthread.php?448805-MPPT-Solar-Controllers&highlight=
So we figured that there are advantages to running two panels off the arches in series to increase the voltage to 24V but keep ampage the same. We then use a MPPT controller and we're all happy. Often recommended is the Victron 70 series that come in a 70/15 (<200W) or 75/50 (<700W).
So i contacted Victron to clarify some points. I might add that the Email support from Victron would bloody awful with one word responses that didn't really address my questions. Anyway many in the previous thread a few people said "make sure you get a big enough controller to upgrade in future". I asked two questions to Victron then:
Q1. Can I get the 75/50 and add more panels to it in different locations on the boat, maybe different powers.
A: No , is not done , you cannot connect different panels to one input , you need 2 mppt controllers.
Q2. Ok can I have two MPPT controllers then for the same bank of batteries?
A: No.
So clearly on a boat solar panels will be on different planes and likely of different powers. They said I can't have two MPPT controllers and nor can I input panels of different power ratings into a single controller. I seem to be in a bit of a loop hole. Is this advice correct?
What I am basically trying to see is if I can wire in two sets of panels in series to same batteries. I.e. does this work:
A: No.
