Mouting brackets for name plates
Harry.c.
5 Apr 2019
Hi,
I'm creating a bespoke mounting bracket which is going to be attached with stainless steel screws.
Can anyone recommend stainless steel screws with a pre-applied threadlocking compound to secure it in place so that the plate doesn't come off ?
Hi,
Why not just use Loctite ?
You can get a Loctite threadlockers which can be pre-applied if necessary. Seach for Dri-Loc
I ended up getting some screws with nylon patches because the sign will need to be replaced within the frame without using a heat gun.
I'm going to get some aerotight nuts to stop the bolts coming out of the hollow section if its knocked. I've just seen the Nord-Lock washer test videos and they look pretty reliable, especially if we use lock nuts with them.
sorry I dont understand the significance of the comment about a heat gun
