Mould inside lockers and bilges etc...
andrewg
14 Jul 2004
Hi all,
Obvious problem at this time of year moored in the UK, even with a de-humidifier! Anyone got any tips on cleaning the inside of the hull inside lockers etc after it gets mouldy stained? Bleach based cleaners do any damage to GRP?
i mist with laundry bleach in a spray bottle and wipe clean. no, bleach will not hurt GRP, may cut wax, but that is all. on my older whirew hull, a wash down and then mist and wash with clear water leaves a real white hull ready to wax or poly glow.
Daz in the bilges.
Any proprietary mould cleaner in Lockers if a simple detergent/Jif doesnt work.
Circulting air is a good preventaitve - leave lockers/bilges open
Bleach and detergents will all temporarily remove the mould and you'll think its a job done....but what you must do is to kill the fungus, usually black mould, so that it stops spreading. Without having access to some serious chemicals the best product i have found is called Dettox mould and mildew remover. This contains a small proportion of an aggressive fungicide and will put pay to re-formation of mould. Be carefull not to breath in the vapours of this product and ventilate well after using it.
Re: Agreed
Sounds obvious, but be carefull when using the sprays. I did about half a quarter berth with Dettox & then started to feel the benefit of the spray on my throat. Felt & tasted strange for a few hours but I gave up and stopped.
Being a diver, I used a dive mask with a long hose to an air bottle next time.
It\'s bleach...
According to the Health & Safety Executive's information on surface biocides, the only active ingredient in Dettox Mould & Mildew Remover is Sodium Hypochlorite (aka bleach).
