alahol2
The plan is to cut the present stern tube as close as possible to the hull and grinding/sanding back to flush and then either punching the remnent out or pulling out, using the tail thread and jacking bolts.
If your stern tube is like mine (bronze?) it will be threaded at both ends, forward into the stuffing box, aft into the bearing carrier. Once you remove the bolts holding the stern bearing carrier you should be able to unscrew it from the tube. When removing the stern carrier on my boat I had to restrain the stern tube from turning otherwise it would have unscrewed from the forward stuffing box and been withdrawn through the stern.
