Mooring line length ?
Phill
3 Sep 2004
Surrey/Kent borders
I'm off to replace the mooring lines for my Princess 33 this weekend.
Are there any rules for ratios of length and diameter that I should be aware of. I'd always thought stern lines were 2.x lOA and bow lines were 1.5 x LOA. Also existing lines seem very thin. What diameter should I be looking for and lastly what types of rope is best suited?
The boat is only used on the upper Thames and your advice would be appreciated.
mine are length + beam + a couple of yards you can then turn the boat round from the mooring while stood on dry land.but I use some deep locks also so handy for that.
2 Lines LOA X 1.5
2 Lines LOA X 2
Diameter = 1.5mm per m LOA
ie 10m LOA = 15mm Diameter
Nylon. 3 strand easy to eye splice, or 8 strand. Nice to handle, good and stretchy, sinks if you drop an end in the water as you set off.
Buy the longest lines you can afford and lots of them... sort of penny pinching to buy lines that leave you short see.... or worse to have only a couple of lines on board!
See lots of that in the Solent area... bits of rope tied together coz owners wanted to save a few bob.....
Not good form at all!
As for diameter.... the bigger the better IMHO!
You cannot be serious......... Problem is lines have to be handled and excessive length or diameter tends to get in the way of this. On the upper Thames I wouldn't bother with anything longer than 1.5xLOA actually rigged on the boat with perhaps a couple of longer lines kept in the locker for those rare occasions when you might have to raft out and need to rig a shore line.
Well I for one am not farting about up the Thames. Main mooring rpes are 20mm and about 16 metres each. Though I do have some smaller ones for cruising, but also some bigger longer ones as well.
Had some nylon ones once, I gave them away, stiff as a board.
Thanks for that Julie! But if my lines are thirteen metres long and one end is tied to the boat and the other to the shore, how do I get off the boat? /forums/images/graemlins/wink.gif
Doh! I'll use the tender!!!
Don't agree with Derf. Bigger better? Not always the case. Try getting a decent wrap around a small cleat with a big dia. line. Get the correct size. Also lines that are too long can be very cumbersome to handle.
As a Thames boater for many years I am with Pheran.
Too long and they are a real pain in the ... for throwing and general use.
Too thick and you fill up the cleat with a couple of turns and totally unneccesary. If you go to sea, buy some longer and thicker ones but not 20mm.
