bajo
Please could advise be given on the best moorring buoy to use ie the white solid or red inflatable
Until Roy Rogers comes along and lasoos itHaving used both, each for many years, I prefer the round inflatable ones as I find them less damaging on the hull with wind over tide.
We had problems with the design with chains through the middle. Mooring holders took the chain up to the boat which left the buoy down the chain a bit. As the boats bobbed in the waves the buoy slid up & down the chain & the chain wore through the middle of the buoy fairly quickly , thus exposing the foam filling.The Hippo things are great, can't sink and the chain comes through the middle so the mooring is as strong as the chain. They seem to last at least 20yrs and are hard to damage. However the last one I bought was 500 quid and any chain attaching in the centre means the boat is more likely to nudge the buoy.
The inflatable variety are more variable in quality, if you attach them to a link, the buoy shies away when the boat is pressed forward - so there is less nudging. They are cheaper, easier to damage and the whole chain can end up on the bottom. I would avoid those where there is a steel bar taking the strain through the buoy
Buoys with a double rod through the centre have been found to be better provided the rod is not over long so that the buoy slides up & down the rod. To stop this owners bolt a clamp below the buoy on the rod. It happens because some like to pull the buoy up tight to stop it rubbing back along the bow as the tide turns when the painter is long.
Someone else's?Please could advise be given on the best moorring buoy to use ie the white solid or red inflatable
I guess it rather depends on the size of boat. Our club tend to use the white inflatable type - white not red as they seem to get nicked by fisherman. We also used to use hippos but are going away from them as they were so cumbersome to handle by our moorings boat and some damage was occurring to boats as they are hard. Attached to this would be a small inflatable pick up buoy.Please could advise be given on the best moorring buoy to use ie the white solid or red inflatable
You say that you reeve one chain through the other. Presumably you mean you pass one through a loop of the other.My boat is only 22 ft and weighs around 1 tonne so I have a 15m of 10mm riser chain to the main support buoy and a further 5m of 10mm chain reeved through the first chain onto the boat. In this way there is continuous chain from the sinker to the boat with no shackles.
If so how do you manage to pass one 10mm chain through another 10mm chain?
Are you moored in lake in fresh water? In our water 10mm chain would last less than a year & with no swivel , in tidal water, would twist so bad that the chain would be unuseable in a short time.
We have to change 19mm c30 chain every 3-4 years much longer & we find boats are hanging off a necklace. We would never allow a mooring to be placed with only 10mm chain below the water.
We were going to change to polysteel but a 40 ft Jeneau had to go on a temporary one we laid & within a week it had swung round in the wind ( partly aided one expects, due to not having the weight of chain) & the back of the keel cut the 38mm polysteel like a knife. the only boat we have on it now is a drascombe. I would advise against polysteel in tidal waters.Most of the risers where we are, are rope. Ours is 36mm polysteel with 8 ton swivel between that and 19mm ground chain to block. Rope outlasts the thimbles so they have to be checked.
