Zagato
I have an IF Boat (26' long 2400KG) with a bow roller to the side specifically for the Bruce anchor. I cannot weld another bow roller on as the mooring chain would foul the anchor. The anchor bow roller is too weak to use for mooring If I take the anchor off (it will need a snubber to use for actual anchoring, as it is quite a long structure. I cannot upload pictures unfortunately but the leverage has already pulled and cracked one side of the deck whilst anchoring by the previous owner. Not a great bespoke design.
One option is to use a bridle for mooring but I would be concerned about just using rope even with some sort of hose protection. Has anybody used chain with protection and can you make a protecting cover for the bow/hull from the bridle. Itchenor Reach in Chichester Harbour can get serious loads tugging and banging down on bow rollers from passing motor boats and RIBs to the point I have seen them bent and even ripped out. My own quite heavy duty bow roller on one of my last boats was bent out of shape with welds pulled out from the passing wash of powered Marina dwellers!! The roller was almost flush with the bow so no leverage involved either. The key to all this Is perhaps not the rope or chain but whatever is protecting it from chaffing. Experienced advice greatly appreciated. Thanks. Oh and no amount of springs and rubber gizmos dampens the force on the moorings... I am probably going to try Bosham mooring next year as they don,t have the motorised traffic that Itchenor Reach has.... why they don,t slow down or look at the trail of destruction behind them even with the 40footers donkeying up and down, yanking on their chains...
