Devon Boy
Dear All,
I’m currently working on a Moody 44 which has 3 blown air ventilation using that appear to heat through hot water pipes circulating around the boat.
However, there appears to be two valves that potentially control the flow of water in some way, I’m assuming to the heating units. So from the calorifier you can send hot water around the circuit and to the air units or turn them off and have cold air.
But for some reason this seems to not work in any orientation even if the water is hot. There is also a push button labeled “circulating pump” which also makes not a jot of difference! Any ideas??
Picture attached for clarity. iCloud Photos - Apple iCloud
