Moody 35
Kiwi seems to have gone off the boil in the last few years, I suspect partly because the Featherstream has taken a big chunk of the market offering a really good feathering prop much cheaper than earlier ones such as Maxprop. Featherstream has good features (for some boats) like the ability to have a different pitch in forward and reverse, really easy to change pitch if needed and good quality alloys and stainless with better anode arrangement than most competitors. Made in the UK as well. The Kiwi sold on the basis, in part, of being a 3 blade feathering prop for not much more than a 2 blade folder. That differential has been squeezed by improvements in folders and lower prices of conventional feathering.
Bruntons are popular with those who do a lot of motoring or motorsaiing as it ensures the engine is loaded according to the conditions, in most cases significantly reducing engine revs for a given speed. Does not necessarily improve fuel consumption as the same power is demanded from the engine but the lower revs is more relaxing. You could also argue that it can reduce the hours of light load running which you usually get when motorsailing with a fixed pitch prop. There are some boats that it does not seem to suit, and of course it is expensive and needs more maintenance than others.
I have had both feathering props (a JF, predecessor of the Featherstream) and now a FlexoFold 2 blade. The first was on an old wooden boat with a small engine and it was a way of getting a large diameter prop to make best use of the meagre power it produced. The feathering aspect was a bonus, but to be honest I never really found much change in sailing speed. The folder I have had on both my Bavarias and I like it, but although I can just about measure the small improvement in sailing speed at low speed in light airs, it is small. The motoring performance is little different from the fixed prop. I fitted the folder on my first Bavaria after being involved in some extensive trials (using the boat) of a number of different types of props and was fortunate that it was the right size for the new boat. Probably would have kept the factory fixed prop rather than buy a new folder though!
While I think the benefits of expensive props are real, I suspect that many overstate the improvements (confirmation bias?) as a way of rationalising the purchase. I also believe that many people buy them (and other expensive products like nav systems) because they have run out of things to spend money on and don't want or can't change their boats! You have to do an awful lot of sailing and motoring to utilise the benefits in a meaningful way. For example a 5% improvement in sailing speed only really makes a difference if you are doing long distance sailing - might improve daily runs by 5-7 miles. For some, though there can be other benefits, like better low speed handling or getting more out of a slightly underpowered engine.
Perhaps the above explains the reasoning behind my suggestion in post#8. Hope this helps.
Congratulations on your purchase of a Moody and don't forget to join the MOA as you will get more focussed advice than here.
I now have a Moody 44 with a Maxprop 3 blade feathering prop (I also have your old water maker!) and it is excellent in every respect but I can't compare with anything else as it was there when I bought the boat. My previous boat was a M33 with the same engine as yours and the original small 2 blade prop. Pretty useless when motoring into a head wind and also going astern. After much pondering I changed to a fixed 3 blade with 1 inch more diameter and the same pitch. Improved performance enormously and, to be honest, I didn't spot any loss of sailing performance. Be careful when talking to any prop suppliers with the engine output. The Thornycroft T90 (IIRC) is quoted as 39Hp but is down rated in Moody's to 29Hp. This will make a difference to the prop it can swing.
The 35 has a T80 - very different engine from the T90 and guess it probably has a 17" prop, quite unlike the arrangement in the 33.
Of course. But it just happens a lot earlier with a Moody than some modern 35 ft boats
Ok. Have you a particular wind speed /boat speed in mind?
I'm curious why you firstly picked out a Moody 35 as having to motorsail earlier than other boats then widening it out to all Moodys, now its against 'some' modern 35feet boats.
Are you of the opinion that Moody boats in particular are not proper sailing boats and need the use of an engine earlier? If I'm sailing the latest 35'boat and the wind dies, the rain comes on and I want to get home I would switch the engine on. If I was in a Moody (let's just say for arguement sake a 35) I would have started the engine sooner?
Ink
Ink
I was not refering to all Moody yachts as i have not sailed alongside any larger than 35 so the discussion was directed to that size. sorry if I caused confusion.
I feel that the sailing performance of the Moody 35 & also the 31, is a bit over rated . That is all.
It is only my opinion & that does not necessarily mean I am right. I think I am, but there are many in the other camp.
But just look at the RYA handicap list. The Moody does not exactly "shine" does it?
However, as many old gaffer owners will quickly tell us , it is not all about performance. ( Ignore the dreamers!!) Still means that the engine has to go on a bit quicker though. I expect that the OP, at 79 plus years, is no longer looking for that last .5kt & will be quite happy to turn the engine on for that extra boost. I know that I tend to push the start button a lot sooner than I used to do.
By the way- Good on him for getting a new ,to him, boat at an age many would be giving up- I sincerely hope he has a lot of enjoyment for a good few years yet. Hope that I can still be looking forward to sailing on at 79.
It appears you don't have much experience, if any, sailing Moody boats. A good few years ago, we won the club Midsummer trophy in our 346 (very similar to 35), a couple of Jeanneau 352s just couldn't keep up in the brisk conditions:)
Probably badly sailed, because the handicap list ( based on results over a number of race results) will show that a SUN ODYSSEY 35 is faster than a Moody 35 & a SUN FAST 35 would wipe the floor with it.
Thanks to all for the input. Yes Tranona, I agree with all you say. I had a Brunton on my Cat and it was brill but the anode didn't last a season which was a pain. Thanks Pasarell also. Hope the watermaker is working well for you. and yes its a T80 not T90 although I am not sure of the actual shaft horsepower although rated as 35HP, good tip to check before getting another prop though. Thanks! And to Daydream I would say "thanks for the kind words" I am very lucky to be a pretty fit 79 year old but not too interested in racing so I am expecting to cruise sedately and safely with a well stocked booze locker rather than hammering to windward with the rails under! Blue Jade is in absolutely wonderful condition and although I paid top dollar for her she is a real credit to her previous owners and a delight to own. The only faults I can find are the shaft seal needs replacing and the radar seems to have a fault. Seems wrong somehow to buy a boat of this age with no other work to do. She even has copperbottom and has been recently polished. See you all out there!!
