Nick Burnham
The cabin lights in my Jeanneau 805 Leader 'Smuggler's Blues' are fitted in the headlining and very much ON or OFF. There are recesses either side of the ceiling which contain the curtain tracks, and it strikes me that RGB LED strip lighting fitted into here that also had the ability to turn white and which could be dimmed would give a great deal more options for cozy evenings on board. I know that a few people have fitted this sort of lighting, and so I wondered whether I could ask some advice?
This is the cabin where I'd like the lighting to go.
My thinking is to have the controller on the bulkhead at the starboard aft end of the dinette. Then run the wire from it to the curtain recess above, that would link to the strip of lighting that would run most of the length of the recess. Then at the bow end the wire could go behind the curtain to the wooden panel with the mirror at the end, run across behind that, then behind the curtain on the port side up to the recess that would contain a matching lighting strip. So the whole thing is powered and controlled on one circuit. Is that feasible?
In terms of kit, I've seen this which looks ideal, but I have very little knowledge or experience, so would be keen to hear whether I'm on the right lines or whether there is something better I should be considering?
This for the lighting (it appears that the size I'm considering should be able to be wired in series): https://www.led-lighthouse.co.uk/le...ollers/rgbw-led-strip-lights-12v-60-led-metre
And then this to control it which looks like it will allow colour control, the ability to easily switch to white, and the ability to dim the lighting in either colour or white mode: https://www.led-lighthouse.co.uk/le...rgb-w-wall-mounted-led-touch-panel-controller
What do you think?
What do you think?
