paul.norton
Without contacting specific manufacturers, what is the accepted maximum moisture content of timber when gluing with epoxy resin.
Paul
Paul
Paul
Epoxy adhesives cure by a different chemical process. They neither contain water, nor is water necessary for them to form bonds with wood. Epoxies can therefore perform very satisfactorily below 6% m.c. as well as giving excellent bonds up to 20% - 25% m.c., well outside the limits of the other glues. Kiln dried timber often has a moisture content well below 8% and is therefore best glued using epoxy adhesives.
For wood to rot, it needs three things: a particular moisture content, a range of temperature, and oxygen. Over the range of temperature we have no control. However, we can use epoxy coating to keep the moisture and oxygen out. We use only kiln dried wood in our boats. Kiln drying will bring wood down to a 6% to 8% moisture content. Wood only rots at about 20% moisture content. That's a lot of water that would have to enter the wood to bring it up to that moisture content. With our epoxy coating and careful construction techniques, we can keep the moisture content very close to the content it had when we epoxied it. Even if there were to be some breach in the coating, that would only be a local breach. Damage to the boat would be confined to the immediate area, allowing time for repair without any real damage occurring. Rot will not be a problem if you get the damage repaired within a reasonable time. That said, we have never had a case of rot in any epoxy coated boat we have built. None. Part of the credit for this must go to our clients, who love their boats and take good care of them.
Paul
