moomba
N/A
Mine isn't, it is to hand from cockpit or saloon.
Yes, I identify them with AIS - on my Chart Plotter. I find it easier to call them by name than spend time putting in / searching for MMSI's on the radio. Calling them by name has always had the desired result.
I'm not sure about 'potential number of people onboard', but my PLB will alert the powers that be in a 'distress situation one press of a button' and I can follow it up with a VHF voice call as, if memory serves correctly, you also should after a DSC alert.
If you are that sort of person, then you should have a button to press!!!
1.Most Plbs I think I said , as normal there is exceptions
2. when registering for MMSI and Call Sign they ask for potential number on board , although this is never going to be accurate if you a solo then it helps , also if you state 6 max then there not sending the navy out for you.
3.Most DSC radios has there call MMSI number displayed on your settings if you can connect all to talk to each other , simply scroll and press
4.I am glad that you are confident and have been in every situation to be abler to act calm ,never underestimate the effects of Fight and flight on the Human body , some people become the Hulk others a mouse do not patronize those that have no effect on the chemical balance of their brain , I have been taught to be very skilled in situations , but I also learned and was not that person until these skills were implanted.
I am sure your confidence will flow to those around you by your over zealousness.
