MMSI Numbers
dmayes
22 Mar 2005
Berkshire
www.drmsom.com
Can anyone tell me if there is a web site that I can search to see if an old MMSI number has been re-used. I have a radio off an old boat that was destroyed and it has the MMSI number burned in. How do I trace that number to see if I can get it re-used on a different boat (same radio)?
Thanks Neale, it was not there so I still don't know if it has been re-allocated. The licensing WEB site tells me that after 5 years they may be re-used. I suppose I will have to call them to find out if this is the case.
Probably best to ring Ofcom as they issue the MMSI numbers and should have the most complete and accurate records
Maritime section were on 0207981 3147 when I last had dealings with them probably still the same.
I believe the MMSI number references the vessel it was registered to, this information is used in SAR and it is therefore important that it is correct. Because the radio has been registered to some previous vessel it will be necessary to reregister it.
The details below have been copied from Ofcom at
www.ofcom.org.uk/radiocomms/ifi/licensing/classes/maritime/
If you wish to reinstate a callsign or MMSI it will be necessary for you to use a paper application form. It will also be necessary to use the paper application form if you wish to change the name that appears on your licence. This paper application/amendment form can be downloaded at the following address:
http://www.ofcom.org.uk/radiocomms/ifi/licensing/classes/maritime/applications/
Applicants will incur a £20 fee for each paper based "lifetime" licence application. There is currently no charge for amending, validating or surrendering a licence.
But why use the old number. You can make a new registry on line and be issued with a new number, then change the MMSI number in the radio. The MMSI number can usually be changed, if you ask how on this forum with details of the radio make, type, model etc. I am sure you will get an answer.
Good luck, George
