marioxp
I have put mixing valve on boiler to limit the temperature of hot water. After that I have noticed that the water pump starts to work every 1-2 minute. I've also noticed that the water started to flow back out through the water inlet. What could be the cause of this situation?
I tried moving the screw on the valve from minimum to maximum, but it had no effect.
Boat is Bavaria 36 2003.
I have two tanks of 150l, switch valve before pump (I think), water pump with some pressure reservoir...
I don't know where is splitting for cold water and water which is going to boiler.
