laika
Well this *has* been asked before but I'm still not clear on the answer.
I have various odd sized deck spaces I don't need to walk on often. I reckon I can cram 250W of semi-flexible panels mixing 50s and 75s of various sizes. I'm aware of the conventional wisdom: ensure current is identical when chaining panels in series or voltage is identical when wiring in parallel. And the other stuff about mitigating different currents in series chains using bypass diodes and problems with MPPT controllers when using different panels which I might nod at and then quietly ask someone for a bit of clarification in a comedy stage whisper away from camera...
I've been looking at specs for panels from various manufacturers but it seems that Vmp is different for different sizes of panel even from the same range So I am now unclear how you're supposed to do this in practice. I'm guessing that plenty of people have installations which they'll say "this works fine" but are actually suboptimal. I do want to do this right. Thoughts?
And how come people don't make charge controllers with several inputs where electronic wizardry could solve the problem optimally?
