Bouba
Some alternators need to be revved up to get excited and then you can drop the engine rpms and the alternators stay the same.
Crikey Piers you need to fix that. Just get one or two bigger alternators. On my engines the original Cat alternators were de-specced and a pair of mastervolt 150amp (@24v) beasts were fitted. These run to 6000rpm so with a x3 pulley they give 80 amps @24v when main engines are idling. You need a double pulley because there is a lot of torque needed to drive them (4Kw each). http://www.mastervolt.com/products/alternators-24v/alpha-24-150-mb/
It shouldn't matter at all. If you start the engines with the mains charger running, the charger will at first notice a big drop in battery voltage as the engine cranks and will try to compensate for that, the charger has a maximum output that will be carefully protected by the charger. It won't be able to keep up with cranking current draw, but will do it's best without damaging itself. (People do lots of stupid things like short circuit chargers etc and they are designed to withstand quite a bit of abuse, errors etc)
Once the engine is running and the alternators kick in, the charger will see a rise in battery voltage and go into trickle mode or similar.
If the charger is one of the new wizzy ones that periodically charges at a higher voltage than the alternator output, the alternators will reduce output as they will perceive a very well charged battery.
Once shore power is off normal alternator behaviour will resume.
I have been doing this for 18 years on 5 boats, don't worry about it. I doubt the blown genny is related to battery charging issues.
Boat manual may state don't do this, but that could be for a variety of other reasons.
When a standard alternator is replaced with a higher output alternator, you must replace the charging circuit wiring with the proper gauge wire to handle the higher output, otherwise you can cause a fire.
What D speed rpm do you do 16 hrs at? Whats your P speed rpm and WOT rpm.
+2
Piers,
on top of other alternator(s) place "battery monitor" devices on your batt's
That was indeed answered/confirmed, I reckon (#6, #13, #23): yes, they know. :encouragement:do the battery chargers know or can the batteries accept two sources of charge, someone?
Piers, fixing your alternators so your batteries charge better, while good for you, doesn't answer your original question, and I for one would like to know. Running a generator while underway is the only way to get 230v power if you don't have an inverter. Equipment like the fridge know when to switch, so do the battery chargers know or can the batteries accept two sources of charge, someone?
Piers, all the inverters I've seen are either on or off (including my Victron Multiplus 24/3000), but this doesn't mean that they are constantly generating their rated AC current, drawing the required DC from the batteries.it's not intelligent and is manually either on or off. It can provide 2.5kW (set to max at 2kW) which takes, of course, power from the batts.
When the fridges are in standby and there's nothing else demanding AC, they are bound to self-limit their output somehow, otherwise where would that generated AC current go...?
Not sure about how their internal electronic works, but I really can't see how ANY inverter could constantly create 2kW (or whatever) of AC drawing current from the batteries, whenever there's nowhere for the AC to be used.
.... By saying not intelligent, I meant Play d'eau doesn't have a load demand system which looks at total load and activates the inverter/generators/whatever according to demand without manual intervention.
