Misfiring Suzuki outboard DF 70 4 strokes
philoudent
New Member
12 May 2015
Hello everybody, I'm new on this forum and i hope you can help me with my engine problem .
I took a video, the sound isn't perfect but you can see what happens
Misfiring starts at 5 minutes running, no matter the engine rpm. they stop when i slow down at 3000 rpm. There is none alarm
The motor is a second hand, built in 2008.
Trying to fix it we :
- did computer diagnosis ( no failure)
-changed all filters (oil, air, water separator)
- put additives in fuel like water remover and injectors cleaner
- cleaned fuel injection rail and injectors manually
- controlled high pressure fuel filter
Despite it none amelioration
Does anyone has an idea ? We're trying to think to everything, temperature, pressure, electricity, defective part ... Our local mechanic is thinking about a bad contact in the vapor separator tank. We're waiting for a new cable ....
Thanks for your help
As above, start with the simple stuff. HT leads and spark plugs. You could also slightly pull the ht lead off the plugs one at a time. The one that doesn't effect the running is the problem one. Careful though, you don't want stray sparks really :)
Partial fuel blockage?
I know the ECU limits them to 3k rpm when out of gear so perhaps something wrong with a sensor somewhere telling it that it is in gear.
