Mircowave & Honda EU10i & Presure cooker
Al.
19 Mar 2011
Edinburgh
Has anyone tried running a microwave from a Honda EU10i.
If so what make / model, and how were the results.
Re pressure cookers, will the Origo 3000 handle a 24cm pan ok.
Al.
19 Mar 2011
Edinburgh
Microwave highly unlikely to run off the Eu1.0i due to start up loads, ours draws around 1400w. We run it off a 2.0i. which is 1600w constant, 2kw max.
We use a 3L pressure cooker on 2 burner Neptune - http://www.ebay.co.uk/itm/Hawkins-C...-3-Litre-/190744157845?_trksid=p2054897.l4276
Thanks Graham,
I figured that would be the case with the 10EU. so no microwave for me.. :(
As for the pressure cooker, I'm just looking to buy one, that's way I asked, I will abmit i'm looking at stainless steel ones. :cool:
sailorman
21 May 2003
Here or thertemp ashore
charles_reed
29 Jun 2001
Can't advise on microwave, but bought an extremely good Aldi SS pressure cooker for £26.99. Disadvantage was long handle for stowing. Use a Tefal with short handles on boat.
I wouldn't (having owned a single-burner Origo) like to try and cook anything on one (I doubt it would accomodate a 24cm pan.
FirstAway
4 Apr 2004
Durham
My Origo 3000 has pan supports which are 17 cm square, and the complete unit measures 25 cm front to back, so yes it will just fit but it will be sitting on the fiddle bar at the front (if you have one) and will slightly overlap the centre line.
theguerns
16 Jan 2009
We had an origo 3000 on our 6 ton falmouth pilot we used a tefal 4.5lt with the quick lid it worked as well as on the gaz as we live in France we used alcool bruler at 1.20 eoros a lt. Cooking once aday we got 10 days cooking to the lt
NornaBiron
6 Jan 2009
Greece
www.flickr.com
Beware of bargain pressure cookers, once the gasket hardens the cooker becomes useless unless you can get a replacement.
