KellysEye
Dettol will kill mildew but wont change the colour, bleach then whitens it. However if is it ingrained that may not work.
Hello I have just recommended this stuff to another on this forum, try 'Bar Keepers Friend' it was introduced to me last year and I have found it relatively cheap, under£7.00. It removed pollen and rust stains from my 32 year old boat so should be ok for you. Once the job is done, wash down and then put on the right gelcoat Polish. Cheers, kevin
The best mould and mildew remover I have seen is astonish might not work for you but it is great stuff and at £1 from asda you can't go wrong
Bar Keepers Friend is basically just oxalic acid in an abrasive powder base. However, the important point is that, unless the surface is corrected, th OP's problem won't go away.
