barclay
New Member
I am looking for a replacement fuel pump for a 12v MY30 heater, new or good used. Any help or suggestions much appreciated.
A very fianeagrre far to the ettdf tha. The previous experience with webastp a ddbdrspljtterI am looking for a replacement fuel pump for a 12v MY30 heater, new or good used. Any help or suggestions much appreciated.
Thanks for the link, l was hoping to find one that mentioned MY30 in the description but at under £10 a shot a generic one is well worth a try. Like you l find it's an excellent heater, don't want to change it for the sake of a pump.They're a generic item as far as I'm aware, take your pick...
I have an MY30 only use it occasionally but have found it a good heater...
Thanks for your input. This is why l was hoping that l would find one that specifically said it was compatible with MY30 heater. Don't want it under or overfeeding fuel into the unit.These pumps are dosing fuel to the burner so should match the OEM specs to perform as OEM
Fuel Pump
Thanks for that info Pete will check on my pump, but if l remember correctly there are no markings on the pump.Does it say on the pump what the fuel dose is as the cheap Chinese ones are 0.022ml per pulse and if you fit the wrong pump it will over/underfuel.
It stops pumping every so often. The clicking stops like it has seized. Spraying wd40 and poking about inside seems to get it going after a while This does not go down well with the female of the species. So thanks to everyone for their help with this one. Amazon here l come.Take your pick eBay or Amazon as in post 3.What's actually wrong with it?
Fully ?They're a generic item as far as I'm aware, take your pick...
