Fenders
When I bought my boat in April this year the heater wasn't working.
After cleaning the glow plug and changing a fuse all was well.
Today I thought I would fire her up just to make sure all was ok. No joy.
When I turn the fan on cool air is pumped through to the cabins. When I call for heat the red light comes on and nothing else happens even after 5 minutes.
I have checked and changed all the fuses and given the glow plug another clean, just in case.
On top of the heater there is a reset switch. This I pushed to reset and it clicked. I then did the same to the other reset switch in the hot air outlet. This didn't click so I assume it didn't need resetting.
I then reassembled everything and fired her up. Nothing. Still the red light and no sign of life.
Could it be that the fuel line needs bleeding?
I say this because the boat came with a full tank and I have been deliberately running the tank down as I do not know the age of the diesel. At just below 1/4 of a tank I refuelled and the tank is full.
Maybe at a 1/4 tank the fuel line doesn't reach that low and could have sucked in air.
If this is the case then how do you bleed the fuel line? I have looked at the line and the pump. There isn't any bulb to prime the line.
Thanks for any suggestions.
