vas
Your updown ceiling feels much more random (= ugly) than others, more random if less intrusive than even the phantom 48. In particular the chunk of low ceiling that is formed by the corridor above will look very bad imho, seriously ugly I mean, and should be designed out. I'd be looking at offset staircase, eg Squadron 52 and the beneteau above, but it's hard to comment obviously based just on your sketch.
although I shouldn't be allowed to comment as a 43ft mobo owner who converted the 70ies two cabin layout to a 3cabin (15yo son, 14yo daughter...) and crammed a master bedroom on the bow (1side access and 1.3X2m mattress) I sincerely feel that the ceiling will be the biggest problem in your setup.
tbh, I was also worried about lack of any perspectives or 3D views that would help you (and us!) realise and feel the space.
I'm sure you can "dress" the layout so it looks attractive, but as JFM says the randomness of the ups and downs and the squareness of the bulkheads in plan are an important issue to address. Speaking as a designer, I often avoid right angles either in plan or section, creating interesting spaces, accesses and lines of view. Matching that with the right colouring scheme you can easily cover limitations and turn them into features. Assuming you're also a designer, you're well aware of that and don't need lectures on the topic, just didn't see any threading on these paths on the admittedly crude sketch you posted. I understand you may not want to post your work on an open forum, so be it.
All of course imho and without knowing the overall concept, other than understanding we're talking about a 3cabin 42-43footer, probably sterndrive.
Closing, I hope your market research is right in identifying a market for a smallish boat that can receive and sleep many as this concept is working on sailboats (with much smaller internal volume, no-existant privace, et al) but doesn't seem to be addressed in mobos. I assume this is for a reason (which I don't know).
Volos port fe, has around 40 sailboats on charter, and I think 2mobos. June to mid Oct all sailboats are away most weeks, the two mobos are there gathering barnacles...
cheers
V.
