sailorman
They are certainly more expensive, but not better value for money - and not more efficient either. The only difference is that a 12v microwave has the inverter built-in, so they are larger than a conventional mains unit, also more expensive to fix if they go wrong. Furthermore, as already mentioned, 12v microwaves are much lower power than domestic 240v microwaves, so take longer to heat anything. If you are considering a 12v unit, don't forget the bigger cables you'll also need to buy to install it - and if considering a second-hand one, check that service support is available, as the once-popular Samsung model is now discontinued.
I've been using an 850W Tesco microwave with a 1000W inverter for a couple of seasons now, works well, total cost under £150. Just pop in the food that needs heating as you motor into your anchorage, and by the time the hook's safely in, your meal is ready to eat!
I was waiting for William H to tell us that
far better a 240v & an inverter (that has multiple uses) with short 12v cables & longer 240v ones
