yoda
A genuinly interesting project and I can see a market for this type of product. However turning from a project to a marketable product will be the real challenge. Please keep us posted.
Yoda
Yoda
Just a thought but wouldn't a more efficient dry silencer be a better bet than a water cooled exhaust.
It won't consume the power that a pump will, it's not something extra that could go wrong and you could run it way from a water supply too.
Only downside will be that it'll be hot of course.
Yoda
I came across a water cooled jacket on machine guns many years ago. The jacket had lots of radiating/convection surfaces, and it was only when steam came out of the top that you knew the barrel was getting almost too warm.
It wouldn't be too difficult to calculate the amount of heat you need to take out the exhaust by a similar jacket. It would be a useful function to NOT have need of a running water supply.
So you have a separate pump for the water ? This will take up a largish % of the power available to the alternator. Especially if there is a head of more than a metre, and also you have friction loss in the pipes ?
If you cool the exhaust gases below a certain temp, there will be condensation spluttering out of the exhaust pipe.
Silencing the beast seems to be best done by a baffled box, but I can see that you are trying very hard to reduce noise especially from the exhaust, and that's an important design objective for on board use.
Am I living in lala land? I commend the man for trying and nothing more satisfying than making something work, but get real, commercial possibilities? Why try to reinvent the wheel? Millions of cheap Chinese suitcase gennies for anything from £39 to £60 to choose from. Decent SDMOs with honda or kholer engines, as light as a feather and quiet too from £239, why bother?Matt,
Interesting project - good luck.
There may be commercial prospects, although now you've given away the idea here, some Chinese corporation may be the beneficiary!
The only thing going for the project is the fun in making it work, it certainly wont be practical, I mean to say a naked air cooled 25cc engine screaming its nuts off? (Cooling the exhaust gases wont stop the cylinder and head getting hot) Commercial possibility, I think not!
Stu
miserable git, just too many people on here poo pooing everything, throwing some maths about when they dont really have a clue!
Looks fascinating, good luck with it. Soldering up the copper will be fine. However I would suggest you give serious consideration to the use of silver solder (hard solder). That melts at >600C and will be rather more resistant to inadvertant dry running. Even proper plumbers solder, the stuff you have to melt with a blowlamp as opposed to even a 100W iron, would be a better choice than basic soft solder.
Not to jump on a bandwagon here, but that's a bit out of order. He praised your work and pointed out a potential problem which you may or may not have thought of.
I would have thought a simple "no worries, I've got that covered" would have been a more apt response, but hey ho. What do I know.
As for the project, good luck with it. I'll be following with interest since I could do with a mini gen. I'd get away with 5amps of so though, so had pondered on a petrol powered model plane engine or similar. Just an idea, I hadn't thought it through properly... ironically, Skipper_Stu's reply would have been a help to me in this case.
Typical forum squabble, but the corporate speak that you use tends to get peeps backs up.agreed and i apologised right away, he does however seem to have a negative attitude problem....
Bottom line the 33cc kholer engine in my SDMO runs my 20 amp battery charger, a 60 watt light, my digi tele and various phone chargers all at once. It does it in a package that I can easily get out of the locker, put on the sugar scoop and plug on to my shore power line. It does it so quietly that the boat moored alongside me cant hear it when it is running.
As I have said before, why re invent the wheel? Satisfying to make something work but hardly practicable as a long term solution
Stu
You see, entrenched attitude, I told you what it does in the real world. Casting doubts on my words just makes you look silly. The bottom line on all these engines is that they all produce much the same amount of power, nothing can change that so the output, whether it be volts or amps or whatever is much the same, so driving your alternator it will only put out so much power, much as my SDMO will. Power = charging ability. Plus to answer some of the other comments, the cost of the pump and alternator PLUS the enjoyable time put in to the project will make it just as expensive as buying my SDMO genny.er...once again, because it will be just over half the weight, do 40+ amps, which is double? and will be quieter....i have a Eu10i (and a kipor IG2000) and am trying to replace it...cos i want more 12v output and something smaller, lighter and quiter....
saying your neighbour cant hear it running is just nonsense, does anyone have a 1kw generator that when running (under load especially) on the sugar scoop they or their neighbour cant hear it.....might be just me, but i sure can....
