slawosz
Hi,
my Mercury 3.3 telltale water flow is very limited - only drops of water are coming off, it used to be solid stream. It happened recently, as I used it just few time for like 500 yards tender commute. I might hit ground with it - mud, gravel and so on - maybe it got stucked in waterways?
I was flushing it yesterday (in small bucket), and I noticed it spits water through 2 small holes in front, few inches above propeller shaft.
There is not a lot resources on the web, especially no repair manual, but I read some horror stories about resembling gear linkage - in case I would need to change impeller.
If I will lift from the water and there is water coming off the engine - is it sign it works fine?
In worst case, how long I can have engine running before there will be any trouble?
There is second thing that happened yesterday - when starting for flushing I heard loud thud - though it was bucket cracking - turns out it was rubber cover of inspection hole that was blown away - I wonder how come there was pressure to make it happen?
Besides, engine works fine, starts almost immediately, and is stable on low revs.
