SeaStu
Hi all,
Any suggestions for what may be happening here?
Mercury 115 (2018), approx 150 hours, last service 11 months ago, used in salt water.
The telltale when in neutral and at low revs is fine and as would be expected. When the revs are increased to over 5000 rpm the telltale begins to fade away to a trickle after a few minutes and the overheat alarm sounds. I reduce the revs and go into neutral and shortly afterwards the telltale returns back to normal. After increasing back to 5000 rpm the same thing happens over again. Last time out I had no chance back to come back at low revs.
It's not entirely new this issue but has become steadily worse, previously flushing the engine with fresh water has assisted. More recently after an episode I flushed the engine using Blu Thru through the engine flush port (engine not running) and this caused a noticeably better telltale and allowed a prolonged trip at over 5000 rpm with no problems. However the next time time out I experienced the issues described above.
The impeller was replaced last service and remains in good condition, the thermostat is opening up when the engine is warm.
Thanks.
Thanks.
