Stephen W
Warning light came on saying "Sensor power supply voltage is low - non critical.
Engine wouldn't start although battery seemed ok i.e. starter turning over but wouldn't start.
Battery man looked at battery and connection was loose. He repaired and tested and all good.
Warning message still showing however even though battery showing 14 v.
Went out again and engine restarted twice out at sea but didn't start in lock on the way back.
Same message showing - battery reading showing 12.5 v and 61.5 hours.
Battery man said this was normal and engine should have started.
Can anyone help?
Does the system fault need resetting - I have reset on boat but system fault message still showing
Stephen W
Engine model is : Mercruiser 8.2 Mag 380hp V8
Can anyone help?
Stephen W
