lovezoo
You can't beat the simplicity of the single prop design:Nearly forget to add needs 2 props cos it will not work properly with one !
Or you could have it even easier to get at on the back of the boat held on by 6 nuts. If you want to work out whether that pool of oil in your bilge came from your gearbox (like in the shaftdrive thread I linked to) you either post on this forum to ask what other shaft drive owners think, or just open your engine compartment on your outdrive boat and take a look at the drive lube reservoir bottle.Or you could have a gearbox nice dry and easy to get at on the inside of your boat.
<snip>
The annual maintenance on an outdrive consists of changing the oil and 8-10 pumps of grease on 4 grease nipples - that's it.
<snip>
"The bellows and seals last a lot longer than the 2 years you like to make out "
"Of course they do"![]()
