James12345
New Member
Hello
I’ve just bit the bullet and fitted a reconditioned 4.3 efi v6 mercruiser after the last one suffered water ingress and self destructed.
I’ve got a weird oil leak from the starboard side that is coming from under the exhaust manifold, it’s actually blowing out at about 2000 rpm, a slight splatter effect where I hold my hand under there. I can’t get in to see more. Any ideas what might be wrong?
There’s another leak from the sump or front pulley
Had to put a litre of oil in after only 2 hours use.
As a side not, I think it’s this oil that is dripping onto the starter and electrics in that area and blowing a fuse that helpfully cuts the engine (fuse that also / only controls the fuel pump?)
Any help most appreciated thanks
