MystyBlue2
Ok well today i have removed carb and all the tiny screws and cleaned out all the tiny orifices with copper wire and sprayed carb cleaner into each and every single hole then blasted with compressed air. It looked pretty clean anyways when i took it apart but i spent 4hrs making sure everything was super cleaned and blasted. Also before i removed carb i sprayed some carb cleaner into carb throat when engine was running and no increase in RPM at all. Did not make any difference to revs or engine pitch, Still died.
Ive downloaded a manual and set all screws to factory spec.
NEW ISSUE!!
now wont even fire up!!
Primer bulb is firm and stays firm, new fuel and plugs cleaned all earths i could see under the cowl and NOTHING!!
i double checked carb specs with manual incase i did it wrong and still the same thing.
Redone a compression check with different gauge and getting 120psi on both cylinders so i removed the plugs and earthed them to the block.
Top cylinder is like a lightning bolt and bottom cylinder is dead! No spark at all. I switched the plugs over incase of a faulty plug and same thing. Bottom cylinder no spark
Would a bad bottom ignition coil cause my previous problem and now a completely non running engine?
I would expect it to atleast fire up and run like a bag of spanners just on one cylinder.
Any help here will be greatly appreciated thanks
NEW ISSUE!!
