Searush
No, it's not the Major or Kwacka, I've just had a Notice to Mariners from CHT to say that the Outfall Beacon at Beaumaris has been broken off leaving the stump poking up out of the sand & mostly underwater. Please give the point plenty of clearance to minimise risk of ripping the bottom off your boat ot knocking blades off your prop.
Sorry, I am unable to attach the file due to the silly forum size limits being exceeded by 1kb!
However, if you pm me with an e-mail address I will fwd it to you. It is not yet posted on the CHT web site.
If you know the area, it is (was?) the post with a green triangle on it just before you getto the pier when entering Beaumaris. There is a green channel bouy beyond it, it would make sense to treat that as the inshore marker for the time being - I normally cut the corner quite a bit, but won't now until it is sorted.
