geem
I wonder why most engine manufacturers fit mechanical pumps?
My Perkins M92B has an electric fuel pump and the Sole diesels also use them. As others have said they make bleeding the system very simple.
Probably an unnecessary addition but I'd tend to have the backup of the electric pump and leave the mechanical. In 30 years and 3 engines I've never has a lift-pump go... there's a first time for everything.
Much more urgent and certain to fail - spare raw water pump and alternator.
My raw pump is so difficult to remove I could never do it at sea.
Really? What god-awful engine design is that?
(Or is this a cunning reference to the fact you have an outboard?)
You may well find your Volvo pump is in that category if it is anything like the earlier 2030 - would not like to remove that at sea!
I think the last vehicle I owned with an electric fuel pump was a Triumph TR5a with Tecalmit(Sp?) mechanical fuel injection, but that delivered more than 100 psi. Before that a 1960 Land Rover. Since then I have owned several vehicles that had done well over 100,000 miles and worked on many more. All had mechanical fuel pumps and none had ever failed.
I had an electric pump in my moggie minor - it used to stick sometimes and require a sharp clout with a heavy object (usually a shoe) when it would tick rapidly for a while. IMO anyone who proposes swapping over to one of those is deranged.
The one in the Land Rover did the same. Maybe the design has improved a bit in 50 years but, like you, I still wouldn't have one.
I wouldn't change it, if engine manufacturers though an electric pump would be better than a mechanical pump they would have fitted it. None of them have.
Here's a pic of my water pump
Would it perhaps be worth getting some knurled-head screws so that at least you don't have the faff with the screwdriver? One of Kindred Spirit's previous owners had done this and it did make life easier.
Easily obtainable as spare parts from Speedseal.
