vas
Hi all,
since JFM was kind enough to donate a series of kit to my project boat, I have to find some data to show to all these GMI-10s.
Decided to use two of them on the f/b helm instead of the VDO tachos + 3 warning bulbs, making a much neater layout.
Problem is my IVECOs (8061SRM-33, 330hp) are mechanical units and hence no ECU or other way to get data off them.
OK, no problem other's taken care of this and we now have a few options all "stealing" data (voltage mainly) from the engine installed sensors (temp for oil/coolant, pressure for oil, air, tacho, etc) and via a black box convert them to NMEA2K messages that are broadcasted on the network and picked up from (in my case) GMI-10.
Managed to find 3 options which I'll explain next and I'd like to know if I'm missing something so that I can have a complete view before deciding on what I'll get.
Mind I'm NOT touching the fuel metering options that are tbh WAY TOO expensive with cheapest quality one is inxs 1K euro for ONE engine! (black box + 2X metering sensors) and I cannot justify the cost nor see it paying off anytime.
So options are:
Maretron
Unfortunately supporting ONLY certain Yanmar diesels via a plugin ECU or whatever socket. So out of the Q [that was easy!]
Actisense Engine Monitoring Unit [EMU-1]
+ Nice package, 6 gauges, 4 alarms, 2 tachos, 2 aux (not working yet), off the box support for VDO 12V and 24V gauges (that's what I have!)
- needs an extra usb/NMEA2K interface to program the box, current firmware WONT support 2 engines as yet, unless you have Faria, US Marine or VDO gauges things are getting difficult as it's not quite clear how you go on about setting them up (says contact them)
total cost comes up to around 500euro (ebay)
NoLand Engineering RS11 Canbus Engine Data Converter
+works off the box with 2X tacho, 4X gauges and 2 X 0-30V input (for alt volt most likely, but can be used for alarms or other gauges) and does support without anything else 2 engines. Programmed using built in usb port, config prog needs two values to accurately tune each gauge, easy to do assuming you DO have a gauge installed!
- 2+2 gauges/alarms less than the Actisense
On the plus we should also note that they cost 210euro for one, or 360euro for two == means that it's cheaper than the Actisense with even more sensing capabilities on the twin option (prices from their online shop). Frankly the single one should be sufficient.
Only thing that bothers me is that the 4Xgauges are 0-20V input so I need to check what my gauges output (boat is 24V but it's most likely a much smaller range per sensor)
Assuming I'm ok with the 0-20V output, I'll get one of them, install it on the bulkhead under the lower helm gauges and hook it up to the NMEA2K network that passes by.
So, anyone has another candidate or anything else to suggest?
cheers
V.
So options are:
Maretron
cheers
V.
