Mechanic required Weymouth
lanerboy
15 Aug 2012
burton on trent, boat in weymouth
Does anyone know a good mechanic that could carry out a full leak down test on one of my D3 engines in Weymouth. I've spoken to two locals and neither knew what a leak down test was, they were trying to tell me it's the same as a compression test but it's not.
Any help appreciated
Where you
talking to Mechanics or Marine engineers ? - there is a difference
Not when it comes to a simple leak down test a good mechanic would be just as capable to do this as a marine engineer
A dealer will plug in the vodia to carry out a cylinder balance test , it’s basically a compression test that works by closing the fuel off and turning over the engine , the computer does the rest then gives a reading on each cylinder . I’ll drop you a message.
Hi Paul, what sensor is calculating the cylinder pressure?
