Mea culpa
Danny Jo
13 Jun 2004
Anglesey
Seeing as Scuttlebutt seems to have a started a new line in searingly honest confessions, from consumption of intoxicants to flouting of colregs, perhaps the team would care to comment on this one.
The occasion was Freestyle's passage last week from Ardglass in Northern Ireland to Menai Bridge, a distance of 85nm. The wind was southwesterly, force 3-4, and to ensure a daylight passage we started early and motorsailed (sin 1, unnecessary contribution to global warming). To avoid crossing the TSS around the northwest corner of Anglesey, I set a course that took us just outside the northeastern entry to the TSS. (An attempt to cross the TSS at that time would have involved being swept by the tide back almost as far as Carmel Head.) About 6 nm northwest of Point Lynas, the visibility fell to around half a mile, but because of around 1.5-2 knots of contrary tide, I maintained our cruising speed of 7 knots or so through the water (sin 2, failure to reduce speed in poor visibility). The radar transponder was switched on. So was the radar, but it cannot be seen from the cockpit (sin 3, poorly-founded vessel) and with only two persons on board I felt it better that both of us should maintain a lookout in the cockpit (sin 4, failure to keep a lookout by all available means). Alan went below to put a fix on the chart, glanced at the radar and said "We've two targets on the port side." Swopping places with him, I noted that one was about 1.5 nm astern, while the other appeared to be dead ahead, and closing fast (not timed precisely, but the gap closed by 0.5 nm in about a minute). From its speed, I felt sure that it must be a ferry, and therefore presumably had Freestyle on her radar, but how can you be sure? (Q1). I was considering making an abrupt 180 and slowing down, when Alan called "There she is, she's passing to port." Not so much looming as rocketing out of the fog was indeed a ferry, proceeding as if to enter the TSS, and passing about 3 cables astern of us. It seems to me that on this occasion the main "benefit" of our radar was to scare the shxt out of me.
It's not over yet. As we had achieved our objective of clearing the northeastern corner of the TSS and the tide was slackening, I altered course ten degrees to starboard, without checking the radar or looking behind (sin 5, bloody sloppy seamanship). The visibility had improved and Alan asked if I had seen the container ship on our port quarter. I hadn't, but noted that our course change had converted an overtaking situation to a potential collision situation. By the time I had established this, the ship was around 0.75 nm away, so I bore away and jibed around onto a northerly course to make it clear that I was giving way. I was not, to my shame, flying an inverted cone (sin 6, failure to display day signals specified in colregs). Blow me if I don't then find a small open MOBO bobbing around on the ocean, fishing rods out, 3 cables away on my bow. OK, so it wasn't in the TSS, and it was between the east-going and the west-going traffic, but would you be happy fishing in fog in a small, radar-lucent boat in an area of relatively heavy shipping traffic? (Q2). We turned again, setting a new course for Puffin sound once we were clear of the stern of the container ship.
My question 3 is this - suppose that before the fog had lifted I had spotted the container ship on the radar coming up astern. It would have been easy to determine that she was the "overtaking vessel", but less easy to determine whether she was intending to pass to port or to starboard. What is the appropriate action for the yacht in these circumstances?
douglas_family
30 Apr 2007
west sussex
Q1 - doesn't matter what it is anything traveling fast is going to hurt , turn to starboard and change your underware.
Q2 - No !
Q3 - Stand on and wait till she passes before changing course or give her a call on VHF
Sorry, I can not follow your course direction but next to a TSS I would be scared silly of I ended up in a overtaking situation. The most dangerous place on a TSS is at its end. There is a nearly 100% probability that a ship will be changing course and so predicting its path is impossible. So either use the TSS properly or get well away from it. Quite a lot of TSS markings have ! sections on the end to highlight the dangers.
That TSS is a nightmare anyway. It has a bend in the middle which with the 90 degree rule makes it impossible to cross. You can not be 90 degrees to both sizes.
However. when we crossed it, we used the 1/8 of the way along point and travelled along the edge until it was clear enough either side and crossed. Pausing in the middle.
Q1. Did they know you were there? For that you need feedback. The most obvious would be if all ships transmitted their ARPA radar outputs. But since sense does not enter into shipping electronics you only have VHF left. You have radar and GPS so can easily get the ship position. OK before some one starts on about VHF assisted collisions I mean only to ask them if they know you exist and definitely not to try and negotiate your demise. Even then doubt their answer and make them confirm it.
Q2. Fishing in shipping lanes in the fog. Natural selection at its best.
Q3. There is only one requirement and that is to ensure they have seen you. Lights, horns, bells and the answer to Q1.
But not getting in the situation is better still.
Danny Jo
13 Jun 2004
Anglesey
[/ QUOTE ]Yes, and this lesson is now firmly embedded. I'll know what to say the next time my crew says "Why stop at Port St Mary (Isle of Man)? Let's start early, go straight home and beat the weather." If I attempt that passage again, I'll do a formal crossing of the TSS. Being swept back to Carmel Head isn't the end of the world if you then have 6 hours of favourable tide carrying you East (as I would have done).
graham
Re speed in fog. In half mile vis I think 7 knots is fine,you could stop or turn in much less than the lim it of your vis.
Richard10002
17 Mar 2006
Manchester
Couldnt you time your run to have fair tide to the North of Anglesey? I'm equally guilty of bucking the tide here on one occassion, but will never do it again, (partly cause I'll probably never go there again).
Slow down is alway an option,if a little frustrating.
jimi
19 Dec 2001
St Neots
O SOLE MIO
Che bella cosa na jurnata 'e sole,
n'aria serena doppo na tempesta!
Pe' ll'aria fresca pare gia' na festa...
Che bella cosa na jurnata 'e sole.
Ma n'atu sole
cchiu' bello, oi ne'.
'o sole mio
sta 'nfronte a te!
‘o sole, ‘o sole mio
sta 'nfronte a te!
sta 'nfronte a te!
Lùcene 'e llastre d'a fenesta toia;
'na lavannara canta e se ne vanta
e pe' tramente torce, spanne e canta
lùcene 'e llastre d'a fenesta toia.
Ma n'atu sole
'o sole mio
sta 'nfronte a te!
sta 'nfronte a te!
sta 'nfronte a te!
Quanno fa notte e 'o sole
se ne scenne,
me vene quase 'na malincunia;
sotto 'a fenesta toia restarria
quanno fa notte e 'o sole
se ne scenne.
Ma n'atu sole
'o sole mio
sta 'nfronte a te!
sta 'nfronte a te!
sta 'nfronte a te! MY OWN SUN
jimi
19 Dec 2001
St Neots
Re: O SOLE MIO
Partono 'e bastimente
p' 'e terre assaje luntane,
cantano a buordo e so' napulitane!
Cantano pe' tramente
'o golfo già scompare,
e 'a luna, 'a miez' 'o mare,
'nu poco 'e Napule
lle fa vede'...
Santa Lucia,
luntana 'a te
quanta malincunia!
Se gira 'o munno sano,
se va a cerca' furtuna,
ma quanno sponta 'a luna
luntana a Napule
nun se po' sta!
E sonano... Ma 'e mmane
tremmano 'ncopp' 'e corde...
quanta ricorde, ahimé,
quanta ricorde!
E 'o core nun 'o sane
nemmeno cu 'e canzone,
sentenno voce e suone,
se mette a chiagnere
ca vo' turna'!
Santa Lucia,
luntana 'a te
quanta malincunia!
luntana a Napule
nun se po' sta!
Santa Lucia tu tiene
solo 'nu poco 'e mare,
ma cchiù luntana staie,
cchiù bella pare!
È 'o canto d' 'e Ssirene
ca tesse ancora 'e rezze,
core, nun vo' ricchezze:
si è nato a Napule
ce vo' muri'!
Santa Lucia,
luntana 'a te
quanta malincunia!
luntana a Napule
nun se po' sta!
