pandos
Headed off yesterday, and beat with reefed main and foresail, into what must have been more than f6 with huge swell running, right on the nose. (at times seemed like an episode of Deadliest Catch.
Eventually with about 10 kts to go to our planned overnight spot I decided to relent and to motor on-wards.
Started engine, it seemed sluggish and would rev right off the scale, (4200 ish) until it was put in gear, it then only would manage 1900, it was rough and sounded terrible with a horrible vibration and we were only able to make 1.2 ks over ground (it was into wind and waves and tide).
Fearing the worst and in the interest of safety I turned tail and sailed back to where I had left from, arriving back at 12.30 am ( of course wind died soon after I turned tail)
This morning my son, put on a wet-suit and scraped barnacles from the prop apparently it was covered in them, this made an immediate difference and we had a huge improvement and most likely the engine is back to how it has been for years, it now revs to a max of about 2200 and trots along at 1800 which is what I would generally run it at.
Question, should the engine be able to rev up higher when under load ? and if so what do I need to look at ? it does not emit bad smoke or sound bad so I am confused. If it was an injector I figured i would get clouds of smoke, if worn out engine likewise I expect blue smoke, no oil being burnt.
