jac
Coming back into the Hamble this afternoon and experienced something that I suspect is fuel starvation but would like the collective wisdom here as well.
Engine has done just over 20 hours on these filters and up till this afternoon, working fine. Tank is only about 1/3 full - last fill was last autumn. Fuel is treated with Marine 16. Boat is a Dufour Classic 36. There is a known issue with fuel tanks on these where due to the shape of the tank, 1/4 should be considered effectively empty. Tank does not have an inspection hatch so unable to check.
Engine started absolutely fine but revs rose and fell - maximum revs with WOT were massively down (rev counter is dead so exact figures unknown but seeemed to be about 1500 rpm)
Engine ran consistently so we came in without incident- just slow speed. After idling, the engine would achieve full revs but then die backdown to circa 1500. Looking at the bowl n the primary filter, it all looks clear but not changed the filters yet.
My view is this feels like fuel starvation. My assumption is that we may have picked up some diesel bug and that due to the tank being pretty low, one of the filters is partially clogged, limiting the flow of diesel. Drop the revs and the system catches up enabling full revs for a second or two but the blocked filter soon prevents any further high revs.
Plan is to change both filters next time I’m down, fill with fresh fuel and give plenty of biocide. And see what happens.
Anyone got any further thoughts/ am I missing anything?
