MM5AHO
My VP MD 2030 has started using fresh water. No leaks visible, suspect to goes to the seawater circuit and out exhaust. Reseating tube bundle has not helped. Any suggestions? Using about 1L per hour.
Wouldnt that be a seawater leak?It could
be a leak at the heat exchanger exhaust elbow connection due to corrosion of the heat exchanger. Take off the exhaust elbow and check. You do not want water getting Into the cylinders
Thanks for the lead. This sounds plausible, sorry I doubted to start, maybe misunderstood. Will investigate.If there us a leak in the freshwater jacket then the freshwater can be forced into the exhaust manifold and then either be ejected through the exhaust system or find it's way into the exhaust port and then into the cylinder. The 20x0 engines have a weak point in this regard which can lead to heat exchanger failure. If you google MD2030 heat exchanger failure you will find plenty of photos
It's either leaking through the HE core or rubber boots into the seawater flow or leaking into the exhaust manifold. If it is leaking through the core/ boots you might be able to manage the situation by topping up and not running the engine hard. If it's leaking into the exhaust manifold it's only a mater of tome before water finds its way into a cylinder. You really need to find out which of the above scenarios you have
I had a similar issue on my MD2040. I replaced the elbow and end caps at the same time and it was fixed, so don’t know which of the 2 actually sorted it. I did find that I could quite happily run the engine with the heat-ex cap off (with a cloth over the hole to stop coolant spitting out!) under medium revs and the engine was quite happy without needing the freshwater circuit pressurised until I fixed it properly.Further advice sought: we are tied by the 90 day rule by time, and autumn storage by place. So we will have to use minimal engine (we do that anyway). However today we had to run engine for 7 hours and lost 700ml of coolant. I am wondering, if that is a constant then, I can get away with max of 4 hour stints in our return to home base (400NM) with monitoring and replacement. Once their, we will have facilities to repair.
Thanks, I plan to do all that. Just thought I'd be able to test without removing anythingWhen you take off the exhaust elbow you can inspect the exhaust outlet of the heat exchanger for any small holes or evidence of a water leak. You can also check the exhaust elbow for blockages where the seawater enters and clean or replace as necessary.
To test the Heat exchanger tubes you need to remove the bundle from the heat exchanger, re attach the rubber boots, block one end off and then connect the other end to a water supply and check for any leaks. Lots of pictures and videos if you google.
