JohnGC
In order to change the coolant I removed the drain plug. This is the first time I've attempted this job myself.
Much to my surprise, no coolant came out and I'm seeking an explanation.
There is coolant in the heat exchanger at the normal level.
The engine runs normally and doesn't overheat with revs up to 2500.
I removed the filler cap to let air in.
The drain plug is located awkwardly and I can't see into it.
I tried poking the hole with a bit of bent wire. That seemed to fish out small bits of black gunge but I didn't want to risk damaging something internal so I didn't poke hard.
Is there an extra step which I've missed such as a seal behind the plug which also needs removing?
