Jokani
I am in the final stages of swapping an MD2B for a newer MD2020B, but I am unsure of the correct cable connections for the alternator and starter motor.
The questions I have are:
- The photo of the engine, the starter solenoid stud, there are two red wires currently connected, is it fair to assume that these are the 2 R2.5 connections to the starter relay and the glow relay? Therefore this stud also needs an R10 connection to the B+ of the alternator, and an R30 to the main switch?
- The wiring diagram indicates that the starter motor requires a negative connection? If so, what size should the cable be, and where on the starter of solenoid should it connect to?
