rickywright78
Active Member
Can I resurrect this thread and ask how the OP got on? @shaunksb Did your issue resolve itself or what did you do to fix it?
I have a MD2010 that has started having a coolant alarm issue - but it seems to be random... the alarm beeps, and coolant overheat light comes on, but then it goes off again, and could beep on and off a few seconds at a time for a while - sometimes staying on permanently... but if you rev it up it also stops. I've ran it for 10mins at full revs and no overheat alarm... but definitely alarms on lower revs.
It's pumping raw water well and I've recently cleaned the heat exchanger and checked the exhaust elbow so all is clear and clean there. I've also now drained and refilled the coolant... and bought a lazar temp gun to check the coolant and engine temp - and all is within normal range?
Any thoughts or advice would be much appreciated!
