mattnj
So my md2020 doesn't like starting....loads of cranking needed, lots of white smoke and it fires and runs slowly rough ish for about 30secs or maybe 60 with starter....then eventually gets going and runs fine all day (seems to have plenty of power and idles ok with no smoke once warm)
Coolant and oil ok (clean)
I took head off, new valves, lapped in (a couple had some minor corrosion but barely noticeable) obviously new head gasket, stem seals, glow plugs are fine and glow red... New injectors.... Back together... The same...
So I've now taken pistons out, and again, all looks ok, measured bores all well within spec, no taper or marks... Obviously not "new" but I've see a lot worse on engines that run...
I will hone and it will go back together again with new piston rings (old ones were on the bottom end of thickness tolerance)
What else have I missed!
Injector pump is about the only thing left, that I haven't touched.... but it runs a1 when started so surely can't be that?
I've got this feeling it's going to go back together and be the same...
Oh and just to add this just suddenly happened...hasn't been getting slowly worse...just 1 day it didn't start....the day before it was fine on the key...
