CaptainBob
I've just found out that the MD11C in the Centaur I just bought has not had the cylinder head bolts check tightened, or the valve clearances checked, since it was rebuilt around 7 years ago.
As a relative novice to engine maintenance - is this something I can realistically expect to be able to do myself?
If so, where's the best place to buy a suitable torque wrench? And what IS a suitable torque wrench? (Same for feeler gauge?)
How likely is it that I will need to replace the valve cover gaskets? Should I buy some in advance of the job?
My volvo DIY handbook has a handwritten note in it that says "decompressor setting _must_ be checked after each time valve clearance is altered" but I can find no reference to the "decompressor"... what is this? How do I "check" it?
Many thanks!
Many thanks!
