jfm
After all the research done via this forum, I found the article a bit disappointing.
1. There was heavy mention of must-have-VAT-paid paperwork again. I have shipped boats with the companies mentioned without needing VAT-paid paperwork, and had no problems with customs etc. You just need to do it right
2. Th checklist of preparations was a bit odd I thought. Why on earth remove the log impeller??? Why remove electonics? Why have tiny levels of fuel and water, given that you will want to drive to a possible distant final destination at the other end? The comment about customs worrying about your drinks cabinet is just daft within the EU.
3. The guy who had the engine problem with the Sq58 had an unfortunate time but the suggested remedy was quite wrong I thought. Starting the engines on the deck of the transport ship and revving the engines would have met with disapproval from the shippers and would have busted the raw water pump impellers, resulting in overheat on the voyage at the other end. The correct procedure is to drain the exhaust silencers using the taps at the bottom. I'm v familiar with the Sq58 in particular and the exh silencers have a drain cock at the bottom fitted with a hose leading to the bilge. you open the tap and drain the silencers. Not exactly rocket science, and all stipulated in the manual, and well worth the effort at €65k a pop. Bit strange that MBY would endorse running engines out of the water, and blipping the throttles to boot. (I also don't understnad how an engine runs for 20mins with a seized piston, and how cylinder corrosion causes overheating; maybe someone has a theory to explain all that?)
