Simondjuk
I want to build an arch/davits for my boat, but want it to look really right. Consequently, before I start cutting, bending and welding relatively expensive lengths of stainless tube, I want to mock the arch up on the boat, try a few different shapes and layouts, have a good look at it from all angles, and maybe even use it as a pattern of sorts
I could do with something along the lines of giant bendy straws to use as a quick, cheap and easy way of making a readily modifiable pattern, but they don't exist. I considered plastic conduit, but I'm not sure if it will hold the bends even if heat is used, but it's possible.
So, before I go out and buy something which won't work or may not be the best compromise of usefulness to cost, does the panel have any genius ideas of the ideal material to use for such a purpose? I'm not too bothered about it being exactly the same diameter as the final tube, but something similar would be good to give a reasonable representation of the finished article.
