Mastervolt / Paguro / Westerbeke / Farymann - Generator now fixed
superheat6k
10 Jan 2012
South Coast
The so called Mastervolt Whiper 4000 generator on my boat which refused to start turned out to be a Paguro 4000, but I found the spares list under Westerbeke 4.5 bcdt. All generic options actually driven by a Farymann 18D Diesel engine.
So what - well price and availability of spare parts is what. Mastervolt had wanted about £400 for a simple blister panel for the remote control box - I found this for £17 from Advance Yacht Services, albeit labelled Paguro. They also suggested the starting problem was likely to be a corroded exhaust valve - spot on, it had lost about 3/4 of the seat material due to exposure to damp salty exhaust after shutdown.
Unfortunately all that could offered from Paguro was a complete top overhaul kit, so after some googling I found the specific parts for the Farymann engine, and with these part numbers I soon found a diesel firm in Surrey with the parts I specifically required, rather than a kit with many unnecessary parts, in stock, and for just £40.
Message here is do not assume your specific piece of equipment is what it says it is. In my case the cross reference to find the generator's true identity saved me almost £600 on the spare parts needed.
Started first time earlier ths evening.
I deal with the same Surrey firm for most of my genny engine parts, we will keep it a secret who they are, top class I've used them for years now.
I've got quite few ferryman parts here, heads valves, all sorts.
I Cant Beleive your saying this i thought i was the only one who is suffering from this issue, cause i receantly dismounted a Paguro 4000 VTE Generator from a Zaffiro 36 Cranchi for a total overhaul due to the following issues:
Shell Fish in the Head Piston.
Lubrication system failed
Wiring cables melt and short circuited to gather
Rust and corrosion on the Exhaust valve
Oil and temp. Sensor faulty
Generator not generating power (Faulty Capacitor and faulty Resistor)
damaged rubber mounts
water leaks and fuel leaks
and so on.
Im a Boat technician and i have had this issue on EVERY GENERATOR,
Hi paul im looking for farymann parts can you help please
Tony
Help! i think because im a new mbr i cannot sent private messages im trying to contact "volvopaul" i understand he may have the parts i desperatly need can any mbr help
Tony
Hi .. sorry to revive this ...
I’ve a whisper 4000 and it’s not starting now ... had it looked at by someone who got it running but it’s been harder and harder to start .. now it does not ..
Has any one got someone red hot .. ??
Where are you based? Maybe a fuel issue? Presumably you’ve checked the filters.
Try removing the injector and squirting in a small qty of engine oil. If this makes it fire almost certainly worn or corroded valves / seats.
NB following the first post here I did later have to have new valve seats fitted, with yet further new valves.
Thanks ... I did get a bloke to have a look and he said the same thing ...
some easy start will get me through the summer ..
He reckons to take it out and he can rebuild it ..
boat life ......
